Hello to all of the Tom's Hardware community. After researching and looking around the whole internet, I decided to come here in hopes that you can help me. I'm sorry for the wall of text beforehand, but I'm really desperate!
I will try not to make this post too long. I have a rig I made back in 2012 which purpose was to work on 3D & Video, as well as being able to play most of the games at that time. It was a gift from my father, so i appreciate it as much as you can imagine. Well, turns out that after all this time, it's starting to die on me. I had to change the GPU (a GTX 540 Ti, like 5 years ago), and the disc (around 2-3 years ago, when I bought a Barracuda, which lasted me A YEAR, I bought my actual one like 2 years ago). So now these are the actual specs:
I know you would be horrified to imagine the amounts of bottleneck problems it has, but I'm a freelancer with no job atm (I'm lucky I can still bother my parents for a while more), no money either and totally noob to OCing, so basically, I don't have any means to get a new shiny rig nor a lot of options to refurbish my rig. I tried throwing back the CPU with some info I found on stock values, but I might have done some bad stuff. So now, I have some messages on the starting screen, and also noticed some other interesting stuff:
USB Overvoltage detected
CPU Overvoltage detected (both of them not at the same time)
When I connect the mouse into an USB, it reads a mouse AND a keyboard, with no keyboard connected.
If I connect a pendrive, the system reads it with no problem. But when I connect an HDD, the discs start making a sound like they're not getting enough power and aren't found on explorer. I tested the 3 I have on other devices, everything fine.
And I'm trying to figure if it's my mobo which is dying. I tested voltages on the PSU, and I tried every RAM card on the sockets, but they seem ok. I also considered faulty drivers, but somehow Windows isn't fixing the issue.
The thing I'm most concerned with is backing up all my info, which I'm doing whenever I can start the computer, but as for the components... As I said before, I can't afford a new rig for the life of me, so if you could lend me a hand in solving this, maybe I could afford to buy a new component, to extend the life of my rig a little bit more, at least until I save enough to build a new computer.
- AMD FX8150 BE 3.6GHz
- ASUS M5A97 with latest BIOS (r1605)
- 3x4GB DDR3-1333 HyperX Limited Edition RAM (have one in, two sitting around rn)
- Toshiba P300 1TB HDWD110 SATA Drive
- TT NiC CPU fan cooler (300 I think?)
- XFX PRO750W Core Edition 80+Bronze PSU
- MSi GeForce GT 740 4GB (if I'm not mistaken)
