[Help] Building a computer
yasio
57
Hello every one :hello:, I'm building a new computer (gaming rig) and I wanted to know if a Intel core 2 quad Q9300 2.5ghz will really bottleneck a EVGA GTX 460 SE 1gb gddr5. I will also buy a MOBO gigabyte P45T-ES3G with 4gb-8gb ram and a Neo Eco 520c PSU. Thanks alot :)
the core 2 is an old CPU, if you are building a new computer, I would recommend you getting the 2nd gen i3/i5 or the AMD Phenom line. If you can wait, you can even go for the upcoming Ivy bridge CPUs from Intel or cheaper FX CPU's from AMD
No I already own a Q9300, but can you tell me if its gonna B-neck a GTX 560 non-ti gigabyte. Yes a GTX 560. If it does, will it be like REALLY b-necked, like I couldn't get a playable frame rate in any game or would it be barely noticible. I want to play MW3 BF3 Diablo3 (yeh that alot of 3s) Skyrim etc maybe not maxed out but on pretty high res. on my 42'' monitor (HDTV) 720p Samsung.
Thanks ! :)
Awsome, well I'll order it soon! By the way, if my tv is called a 720p screen, does it means that if I plug it with an HDMI cable, the max res I'm gonna get is 1280×720 (wich is fine for me, I don't mind not having a ginormous resolution)
Thank you alot for your time !!! 😀
