[SOLVED] Help choosing monitor.
Dec 28, 2019
Hello everyone. Im going to be buying a monitor for the first time and im not sure which one I should go with. Ive narrowed it down to 3, but im not very familiar with monitors so im having trouble deciding. Here are the 3 ive been looking at.
AOC G2590FX
MSI Optix G24C
AOC C24G1
I have a GTX 1070, i7 8700k and 16gb ram. Which would be the best? They are all roughly the same price. Any help or recommendations are much appreciated. Thanks guys!
Thanks for the response! Just one more quick question. I just discovered the AOC 24G2, do you think that would be a better option over the other two? Thanks!
it sort of seems like a sidegrade to me. I feel like the 2590 is still better overall. Another option for 240 Hz is Acer XF250Q. it is pretty similar to the 2590 but is 240 Hz. it is $50 more though.
AOC C24G1 vs AOC G2590FX
To me it's between these 2. Personally, I like the 24G1, however, the 2590 gets a better score 61 vs 80. I really don't think you can go wrong with either.
Note my preference comes down to quick glances over specs and gut feeling. By the numbers, the 2590 is a better choice.
