Help finding graphic card/ps for HP p7-1254
marand
4
Hello,
I need to find a graphic card for an Hp p7-1254 computer, and suggested power supply. I would spend apprx. $200 or less for the card. It currently has an integrated card with an express pci slot and I dont think it has an hdmi slot. I was thinking either a 6770 or 6870 card, but am unsure what to get. I know the newer cards are larger and want to be sure I get a compatable size and one that will run reasonably cool. I plan to upgrade the ps also. I would guess a corsair 600-650. Could someone give me links to a place like new egg that I could also purchase the correct items. I would appreciate any help on this. Here is a link for the computer specs: http://www.bestbuy.com/site/HP---Pavilion-Desktop---8GB-Memory---1TB-Hard-Drive/4672416.p?id=1218525518716&skuId=4672416
here is the motherboard info: Motherboard
AAHD2-HY (Holly)
Figure 1: Motherboard top view
Manufacturer: Pegatron
Form factor: uATX: 24.38 cm (9.6 inches) x 24.38 cm (9.6 inches)
Chipset: AMD Hudson-D2 FCH
Memory sockets: 2 x DDR3
Front side bus speeds: 100 MHz UMI (Unified Media Interface)
Processor socket: FM1
Expansion Slots:
PCI-Express Generation 2 speed
1 PCI Express x16
3 PCI Express x1
1 PCI Express Mini Card x1
The best option would be a gtx 560 ti. If you think that you can't afford it than you can go for a gtx 560. Just look on newegg and find one made by evga as they are usually the best brand. Any corsair 80 plus rated with 600 Watts will work fine
I finally purchased: MSI R6850 Cyclone PE Radeon HD 6950 1 GB 256-bit GDDR5PCI express and Corsair Enthusiast Series TX650 at New Egg with rebates. They are running well.
