Question Help GPU not displaying video!!
Mar 3, 2018
136
So i flashed my gpu ( 5700 ) 2 days ago, it got bricked, so i flashed it back and it worked perfectly. The day after i turned on the computer thinking it would work but it didnt,
I tried re sloting it, i tried putting the psu cables back on to it, i tried a different slot on the mobo, i tried with 1 stick of ram and resloting the ram, clearing the cmos but nothing worked
The gpu isnt even a week old and its dead, again it was flashed but than flashed back to its original BIOS. So it Should have its OG bios on it. Please help!
Why would you flash a brand new gpu yikes!😳 I know this dosnt' help.... Do you have a friend that you can try the gpu in their pc? If you do see if it works in his pc. If not then you can try and play dumb and return the gpu for a new one.
Ive tried running the gpu in a dif slot if that helps. But i do have a friend yes, and what i think ill do is make him come over and ill try to reflash it and see, the bios may be corrupted
