Help-Graphics card?
xN m F
23
hi im looking for a new gfx card for my main comp so i can play cod4 on.
some info on computer
motherboard is: MSI Amethyst-M
processor: AMD Athlon 64, 2200 MHz 3700+
Ram: 1GB SDRAM PC3200
the one my friend thougth would work is
http://cgi.ebay.co.uk/Gainward-Bliss-8600-GT-512MB-HDMI-SilentFX_W0QQitemZ270400379771QQcmdZViewItemQQptZUK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW?hash=item3ef51e5b7b&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1690|240%3A1318|301%3A0|293%3A1|294%3A50
tht is the link to it.
thnks for the help.
xN m F
23
how much would that cost as im not looking to spend much i forgot to put tht in my first post
thnks
The airflow in a HP/Compaq system is probably not enough for the passive cooler on that 8600 GTS to work properly. I agree with the mousemonkey also about ebay purchased items, they can be more trouble then they're worth. Look at a HD4670 or the 9600GSO in your area to see what prices are like. Here's 2 links to newegg (which i know you can't use, but may be helpful)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121319
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131146
xN m F
23
xN m F
23
okdokey gd thing is im happy with scan as they take paypal so i l probalby go for scan. but to refernce which out of the 3 would hav bets performance with my machine
No, that is just the voltage that we use in the UK, you need to find out the make, model and most importantly the wattage.
Gin Fushicho
1,777
Sounds like someones got a smart mate. ;3 You should listen to her advice.
