Help, i'm locked out of my system
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Hi.
I just turned on my PC and it is telling me that *"System
32\drivers\pci.sys file missing or corrupt, you can attempt to repair
this file by starting windows using the origanal setup disk. please
select R at the first screen" *
but i cant get back to the repair/format screen
I have formatted this machime before by changing the boot sequence from
HHD 0 to Boot from CD. I dont know if i'm missing something here, can
anyone tell me how to get into the system so i can format the HDD and
start afresh.
thanks guys.
Kev
kev1n3@yahoo.co.uk
kev1n3
What the prompt is telling you to do is to boot from the CD and enter Recovery Console (pressing R the first time you see a Repair option). You'll need to know the Administrator password, if any, to get into Recovery Console.
Once in Recovery Console, use the EXPAND command to expand the PCI.SYS (its on the CD as PCI.SY_) to the Windows\System32 folder. Enter EXPAND /? for the command line format and options.
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display\Security
Win 95/98/Me/XP Tweaks and Fixes
http://www.dougknox.com
Per user Group Policy Restrictions for XP Home and XP Pro
http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Please reply only to the newsgroup so all may benefit.
Unsolicited e-mail is not answered.
"kev1n3" <kev1n3.1uwcdp@pcbanter.net> wrote in message news:kev1n3.1uwcdp@pcbanter.net...
> Hi.
> start afresh.
> thanks guys.
> Kev
> kev1n3@yahoo.co.uk
> kev1n3
