Help in choosing cards to run 3x27"@7680x1440
Ah redeemer. What do you suggest I go get besides the one I have now? I mean it has PCI-E and if I put CF then I can have both cards run at 8x8. Is there a board out there that can run 16x8 for Z77? Also, I intend to move up to IB-E when it comes out so I guess this out of question right now!
That card is way cheaper than even the XFX DD GHz and I can pick it up tomorrow, I mean pick up 2 of them tomorrow and will send you 2 the pictures including my 2 monitors that are yearning for their 3rd mate!
Which card? Also, there is no reason for you to get 3 way CF such overkill. Way I look at it get what you can afford now if you need more power get more power but man no need for 3. 2 screens and were talking 3 cards pfft. nope!
The XFX GHz is 439.99 Canadian dollars and it has $30 MIR which will make it 409.99 before tax. So 2 of them will cost me 819.98 before tax with MIR applied and I can pick them up tomorrow and save on shipping too. See what I mean?
Do you think my PSU is more than enough to have these boys (2*XFX GHz) I just ordered running with a IB-E chip (when it comes out) and 360 mm rad + 420 mm rad, 2 pumps?
Don't go SLI or CFX and you won't need the watercooling either..........also micro-stuttering is to consider when going that route.
if you wanna run 3x27" of UHD.....thats a HUGE number of pixels to push!!! and CFX and SLI setup of 2GB+2GB cards are Not 4GB but ONLY 2GB EFFECTIVELY...
so, I would recommend going with a single card solution.
GTX Titan is coming out in a week on 2/18.....should be available to ORDER in about 10 days.........6 GB, 384-bit ......that's what you need to run 3x UHD displays
so hold on for 10 days, and get a Titan. because CFX/SLI has microstuttering + heat +space + efficiency problems....
and NO single card currently available is gonna cut it for ur needs.
its gonna all change in a week.
Well, what the heck. The Titan will have a $1100+ price tag and no one knows for sure if it is real or fake, hence the title rumor. I don't see why I should spend that much money on a single card that can't push 3x2560*1440p at max settings. If it's selling at that price I might as well go and grab 3CF or 3SLI.
I think IB-E should be less power hungry due to 22nm process just like how the current IB i5/i7 offerings are very efficient compared to SB chips.
