Okay so, here's the story. I bought a 2700+, MSI k7n2 Delta-L mobo, 512mb PC3700. So, first, I boot up on my old 300w PSU, and it boots fine, I just wanted to take a look at the options. Then I switch PSU's(my new one arrived, 430w Antec), and after a couple boots, my CPU name/Speed have changed. My 2700+ has now changed to a 1500+ @ 1.3 instead of 2.13. For some reason, and I have no idea, it's changed. So I go into my motherboard settings and change the ratio(multiplier) to 7 to allow me to actually get the full speed out of my CPU(it is running @ 2.8 ghz now). So I believe I have that problem solved, I hope. Now there is are a couple of OTHER different problems. First, my system clock si at 99.47mhz. I don't think that is the correct speed. Second, my system bus is at 198.93 mhz, which I do not believe is the right speed. Third my multiplier is 22, which is hard for me to accept as correct. This all according to WCPUID. Third, I can't figure out how to get Dual Channel DDR to work, I'm guessing that's why my system bus is so low, or if it's not am I just being stupid? I have included a link to a pic of my WCPUID readings right here: http://www.opinionator.net/taylor.jpg . If anyone can help me with this problem I will be forever grateful. If I am just a stupid newbie, I appoligize
Taylor
Taylor
