[SOLVED] Help lots of questions
Dec 10, 2020
Hello I'm not super computer savvy but I know a little. Over the past month I have had a ongoing issue with my PC where it would at complete random no matter what I was doing shut off and restart. That went on for a while then i asked and looked around figured it could have been due to a overheating issue and I changed out the liquid to my liquid cooling setup and it seemed to have fixed the issue. Now to where we are present day it has begun again and I'm not sure why, it recently stopped an has not reset in a few weeks. I play WOW and recently it has started giving me the error code 132, i have tried just about everything to fix it and even hard reset my computer all the way back down to windows hoping that would fix it, but it hasn't. Now my Pc is doing all sorts of odd things like random resets, have of my rgb fan lights wont turn on when just a second ago they were fine, ill get random errors on programs that I recently just downloaded after the hard reset. My main frustrating issue is the WOW one but everything else that has been going on also makes me feel like it is a part of the issue. So if anyone could give me some more suggestions or help me out that would be very appreciated. If any other info is needed let me know.
My Specs:
Cpu-I7-6700k
Gpu-Nvidia GeForce Gtx 1080
Memory- 64g of ddr4 3200 ram
Storage-Samsung M.2 950 pro and a Samsung ssd 860 evo 1 tb (which I just added yesterday to replace an old HDD)
MB- Asus Z170-A
Power- EVGA 850 G5 ( which I replaced my old power supply with earlier due to the old one failing and me thinking it was a power issue)
Custom liquid cooling setup
and a WIFI card I can get name if it is important.
Also another odd thing that happened recently before i did a hard reset, was the computer got stuck at boot until i disconnected my old HDD and then it booted normally, but had an error with my WIFI card not being recognized and I simply unplugged the card into different spots then back to the original spot and it worked fine again, was just odd.
hard reset? what do you mean by this?
have you updated motherboard drivers? have latest bios?
error 132? Access violation? It can be caused by out-of-date addons, corrupted files, incompatible drivers, or hardware issues - https://us.battle.net/support/en/article/8288#:~:text=message.,incompatible drivers, or hardware issues.&text=Update your drivers and operating,and addons are not corrupted.
Hard reset I mean that I wiped the hard drive and did a fresh install on windows. Like went to windows home and went to reset and wiped all my data if that makes sense.
I have been using driver easy to update my drivers and that seems to have been getting all the driver updates but I will try and get the motherboard driver directly.
and with the Error 132 I have tried running with out addons, tried a fresh instal of wow and not downloading addons only for it to crash again, tried scan and repair from blizznet, tried a windows repair on it, and just yesterday it ran for about 6 hours no problem then got the error out of no where but 6 hours was good.
