Help me build my dream computer.
dalexc
19
I want this to be the ultimate computer. Primarily for the purposes of stock trading as well as hd gaming.
I just need help putting this thing together.
After browsing these boards and new egg, here is what I have so far:
Processor: Intel Core i7 2006k - $314.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
Motherboard: ASRock Z68 Extreme4 $189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157250
Harddrive: SAMSUNG EcoGreen F4 HD204UI 2TB 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152245&cm_sp=Pers_StoreTopSeller-_-22-152-245_3_TS-_-1_15___
Ram: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C8 $84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233147&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1gltrtfmn8m8e
SSD: OCZ Vertex 3 VTX3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) $269.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227706&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=o1fkkaosqhqn
Drive:SAMSUNG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model SH-B123L LightScribe Support - OEM - $69.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16827151222
Power Supply: CORSAIR Enthusiast Series TX850 V2 850W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply - 134.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=alusq4r9kvz5
Monitors: Need a lot of help here. I'm looking for a triple monitor set up. Should I purchase three single monitors and align them together or grab a triple monitor that is already connected? For either one, which one would you guys suggest I really do not have a clue here.
Graphics Card: This is also something I really need help with. What are the best graphic card available that are suitable for three monitors?
Case/Keyboard/Mouse/Speakers - I can pick these out myself, but the suggestion box is wide open here too.
So..
First question: Outside of what I mentioned I need help on, am I missing anything?
Second: Do all these devices put together create a functional computer? Yes I am completely new at this.
Thanks in advance for all your help.
Monitors are kinda up to personal taste but this one has great reviews:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
With the graphics card, it depends how much you want to spend but the minimum i would get for that build is HD 6950 2GB such as this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127562
Even better, 2 of them. (If the budget allows.) Your other options would be GTX 570, GTX 580, GTX 590, HD 6970 and HD 6990. I think the HD 6950 would come most highly recommended in terms of good value though.
That would all go together to make a great computer. I would recommend a 7200rpm hard drive though unless youre worried about electricity bills or something. A 5400rpm drive like that will be much slower.
Thanks for the reply.
Would I need two of those graphic card to support three monitors? Looking at Eyefinity, it seems like I only need one?
Also, that monitor looks incredible, but way bigger than I thought. It'll be tough to put three up there. I think I may only need two.
The reason you need 2 of the 6950's is because of the resolution. If you run Eyefinity or any 2 monitors. If you are running HD like 1920x1080, that's running a resolution of 3840x1080 which is pretty large considering a single card already has enough trouble running 2560x1600. So at the end of the day with a tri monitor setup, you are looking at a dual card configuration to run games smooth.
As for budget. What is your budget?
Switch that HDD for this
http://www.amazon.com/Samsung-Spinpoint-Cache-Desktop-HD103SJ/dp/B001U3S5S0%3FSubscriptionId%3D19BAZMZQFZJ6G2QYGCG2%26tag%3Dsquid1240995-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB001U3S5S0
And I recommend two of the 6950's
http://www.amazon.com/HIS-Radeon-256bit-Mini-DisplayPort-H695QNT2G2M/dp/B004WZ0HQ6%3FSubscriptionId%3D19BAZMZQFZJ6G2QYGCG2%26tag%3Dsquid1240995-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB004WZ0HQ6
Ram-wise no need to spend that much, save some money for the graphics and power supply department.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
The Z68 Extreme4 is a great board, no doubt. But the Z68-GD65 is a great board too. Also it runs much cheaper and its in a combo with the 2600K
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.674895
I don't know that you need the 2600K though since in gaming it only performs about 1-2% better. I'd suggest the 2500K to save $100
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.674899
For power supply concerns. I don't recommend Corsair, they're overpriced for the performance offered.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194093&Tpk=Lepa%20850
This power supply although a new company is a solid one.
http://www.hardocp.com/article/2011/06/20/lepa_b_series_850w_power_supply_review/9
Well with Triple screens you would want at LEAST 2 cards; 3 would be best. What kind of case you have in mind to fit this all in?
Ideas:
Case: Cooler Master HAF 942x or known as HAF X
http://www.coolermaster.com/product.php?product_id=6653
Power Supply: Thermaltake TP-1350M SLI approved 🙂
http://www.thermaltakeusa.com/Product.aspx?C=1245&ID=1985#Tab1
Memory: Corsair Vengeance Low Profile Blue
http://www.corsair.com/vengeance-low-profile-blue-16gb-dual-channel-ddr3-memory-kit-cml16gx3m4a1600c9b.html
MotherBoard: Asus P8Z68-V PRO
http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z68V_PRO/
Graphics Card: nVidia GeForce GTX 590
http://www.geforce.com/#/Hardware/GPUs/geforce-gtx-590/overview
Depending on your price range of course (2) of them would be ideal but (3) is best when connected crossfire SLI approved.
Where you buy the items is your choice, these are all ones i listed that I'm personally looking into building myself, only with using GTX 550Ti X3.
Good Luck and happy gaming.
I figured that, but I think having a stand might be best for me because of the lack of space. Every inch counts on my desk. lol
What do you guys think of the triple monitor in my previous post?
I honestly think though the 6950 2GB is your best route, like Darkside said, kind of.
The 6950 2GB gives you that 2GB of VRAM, not it isn't usually important however in high res gaming (1920x1080+) it does help quite a bit. Another thing it is quite a bit cheaper than single 590.
Looks like I am going with the HD 6950. Thank you everyone for all your help. I am sure I'll be here in a week or so crying because I can't put the computer together.
Thanks again.
