B bacon9479 Reputable Apr 21, 2014 69 0 4,630 Jun 9, 2014 #1 so i have the corsair h100i and i just got it but i dont know what cooling to put in it. please help.
Solution bradsctt Jun 9, 2014 Yup, the H100i comes prefilled. Just follow the guide included with the cooler, and you should be good to go.
cball1311 Honorable Dec 15, 2012 1,622 1 12,160 Jun 9, 2014 #2 I comes with coolant pre-installed. You are good to install it. Upvote 0 Downvote
bradsctt Distinguished Jun 9, 2012 951 2 19,365 Jun 9, 2014 Solution #3 Yup, the H100i comes prefilled. Just follow the guide included with the cooler, and you should be good to go. Upvote 0 Downvote Solution
Karadjgne Titan Ambassador Dec 26, 2012 30,750 4,552 142,790 Jun 9, 2014 #4 The H100i is a CLC, a Closed Loop Cooler, you will not need coolant, as it is a sealed system. It's plug-n-play. Upvote 0 Downvote
