Question Help me locate these 2 motherboard slots required for the display screen for my CPU fan-cooler please
SeriousGaming101
330
Can someone circle from the MB picture where these 2 slots are? Thanks
You can find info in motherboard user manual.
#10 - USB 2.0 header
#11 - aRGB header
No cooler documentation?
I found the following link:
https://www.deepcool.com/support/Base/index.shtml?id=GeneralFAQ
From the link -
"I have a DeepCool air cooler, and I am getting a CPU Fan error. What can I do to resolve this issue?
There are a few things that you should check it you are getting a CPU Fan error:
1.Make sure that the fan connector is plugged securely into the CPU Fan header.
2.Test if the CPU Fan header is faulty by plugging in another fan, and seeing if the CPU Fan error is thrown again. If it does get thrown again, it is likely the sensor on the motherboard that is the issue.
3.Make sure the fan speed is not too low. Go into the BIOS and increase the fan speed if it is low.
4.Use compressed air to clean the dust off the fan to clear out any obstructions."
#1. notes, as has been posted, CPU Fan Header.
