Hi all,
I rarely post here, but I research the frak out of any part I'm thinking of buying here. I built my current PC back in late '09, and this year I've upgraded my CPU and GPU to keep up with the times. I use this PC constantly for web surfing, music/video playing, etc., but the only performance-intensive thing I do regularly is game. Current specs:
MSI 770-C45 mobo
Phenom II x4 965
HIS Radeon 6950 2GB
4GB DDR3 1333 (Kingston HyperX)
2 SATA 3.0GB 7200RPM drives: a 500GB (Samsung or Hitachi IIRC?) and a 1TB WD Caviar Green.
Windows 7 64bit
1920x1080 display (I always game in native resolution)
I know my mobo isn't exactly high-end, but I don't want to upgrade that until I'm ready to build a brand new system in another couple years. The GPU is clearly the highest-end part, the CPU should be fast enough not to cap my framerate in games. I've been thinking of doubling down on RAM, but I'm not sure how much of a difference that would make.
I'm leaning toward an SSD drive. I have a 2TB Caviar Green coming soon from newegg. Once I get that, I was thinking of getting a small-ish, high performance SSD, enough room for Windows and a couple games that suffer from long loadtimes or in-game slowdowns when loading new textures with room to spare for virtual memory. The 1TB drive is already mostly full of media files and backups of documents from my other drive, so I'll leave that stuff on there and use the 2TB drive for additional media storage and most of my applications.
Does that sound like a cost-effective way to boost my performance? What can I do to test whether, and by how much, HDD performance is bottlenecking me? Is using my soon-to-arrive 2TB drive for most programs and whatnot a good plan, or would it be better to move everything off the 1TB drive and use that one for programs instead? Or maybe keep using the 500GB drive for that stuff? How well does Windows 7 play along with installing almost everything to a drive other than C:? I vaguely remember this causing some problems years ago, but I assume it's fairly well-supported now.
If there's a better way to spend somewhere in the $100-200 range to boost my performance than adding an SSD to the mix and shuffling drives around, let me know what you think I should upgrade instead! And let me know whether it's worthwhile to toss in 4GB more RAM.
MSI 770-C45 mobo
Phenom II x4 965
HIS Radeon 6950 2GB
Windows 7 64bit
