Help me reduce Cost
gagan2246
4
Hi All,
I am looking to buy a computer and have zeroed on following configuration"
Intel Core I7-4790K 4.0 GHz Processor
Asus Sabertooth Z97 Mark 2 32GB Intel Motherboard
Geforce GTX 970 (4GB)
G.Skill RipjawsX DDR3 16 GB
Samsung 840 EVO 250 GB Desktop Internal Hard Drive
Western Digital Caviar black 2 TB
Seasonic SS-650KM3 650 Watts PSU
Cooler Master 693 Green
BenQ 27 inch LED Backlit LCD - GW2760HS Monitor
This looks good but it is going slightly over budget.
Can you please suggest changes in above configuration so that the cost can be brought down with minimum loss of performance.
I am a graphic designier working in after effects, Corel draw, 3ds max etc. And i also will like to use this computer for gaming.
Thanks
Gagan
This build will give you the same performance, but lacks the ability to overclock. The non-K i7 goes up to 4GHz with TurboBoost, anyway. Your original motherboard is a bit overkill. You can get away with the H-series chipset, which will save you money. I replaced your SSD with the BX100. While not the top performer, it only equals out to a few second difference, and Crucial's are extremely cheap, but reliable. Hitachi makes some of the most reliable HDD's, and usually for cheaper.
Your original monitor is overpriced, and if you're going to be doing editing, you want the best color reproduction, which means an IPS panel.
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor ($286.88 @ OutletPC)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard ($81.99 @ Directron)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory ($117.99 @ Amazon)
Storage: Crucial BX100 250GB 2.5" Solid State Drive ($99.00 @ Amazon)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive ($66.68 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($323.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case ($67.99 @ SuperBiiz)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($51.99 @ NCIX US)
Monitor: Acer G257HL BMIDX 60Hz 25.0" Monitor ($207.58 @ Newegg)
Total: $1304.08
Generated by PCPartPicker 2015-02-23 00:21 EST-0500
A big area to save cost would be the GPU, case and monitor. I realize you may want a 27" and the case is a matter of taste. The GPU would give you extra memory should you need to go multi monitor or 1 bigger one. Just a thought.
http://pcpartpicker.com/p/VJ7cjX
[PCPartPicker part list](http://pcpartpicker.com/p/VJ7cjX) / [Price breakdown by merchant](http://pcpartpicker.com/p/VJ7cjX/by_merchant/)
Type|Item|Price
**CPU** | [Intel Core i7-4790 3.6GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i74790) | $286.88 @ OutletPC
**Motherboard** | [Asus Z87-A (NFC Express Edition) ATX LGA1150 Motherboard](http://pcpartpicker.com/part/asus-motherboard-z87anfcexpressedition) | $74.89 @ OutletPC
**Memory** | [Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory](http://pcpartpicker.com/part/corsair-memory-cmz16gx3m2a1600c10r) | $121.99 @ Amazon
**Storage** | [Crucial MX100 256GB 2.5" Solid State Drive](http://pcpartpicker.com/part/crucial-internal-hard-drive-ct256mx100ssd1) | $104.99 @ Adorama
**Storage** | [Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/hitachi-internal-hard-drive-0f10311) | $66.68 @ Amazon
**Video Card** | [Sapphire Radeon R9 290 4GB Tri-X Video Card](http://pcpartpicker.com/part/sapphire-video-card-1003622sr) | $269.99 @ SuperBiiz
**Case** | [Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case](http://pcpartpicker.com/part/fractal-design-case-fdcadefr4bl) | $83.98 @ Newegg
**Power Supply** | [Corsair CSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply](http://pcpartpicker.com/part/corsair-power-supply-cs650m) | $69.99 @ Newegg
**Monitor** | [Acer H236HLbid 60Hz 23.0" Monitor](http://pcpartpicker.com/part/acer-monitor-umvh6aa003) | $149.99 @ Best Buy
| *Prices include shipping, taxes, rebates, and discounts* |
| Total (before mail-in rebates) | $1324.38
| Mail-in rebates | -$95.00
| **Total** | **$1229.38**
| Generated by [PCPartPicker](http://pcpartpicker.com) 2015-02-23 00:51 EST-0500 |
Thanks Brillius and Royalcrown for your suggestions.
The problem is that I am in India and the components like crucial RAM and hitachi HDD are not available.
warm regards,
Gagan
Okay, well I will poke around. How about the 290 though, that specific one is the best OEM AMD partner and the best 290 cooling setup there is for air cooling. Also, are you going for a large monitor ?
