Help me to choose power supply
Nsync
62
this is my final
CPU : Core i7-2700k
MOBO : GIGABYTE GA-Z77X-UD5H-WB LGA 1155 Intel Z77
Cooler : Cooler Master - V6GT 120mm CPU Cooling Fan with Heat Sink
Vega : EVGA GeForce GTX 670 2GB
SSD : Corsair - Force GT CSSD-F120GBGT-BK 120 GB
HDD : Seagate Barracuda 1TB
RAM : G.SKILL Ares Series 8GB (2 x 4) 1866
Screen : ASUS VE247H 23.6"
BD : LG Black 14X BD-R 2X BD-RE
Case : COOLER MASTER HAF X ATX Full Tower
OR : NZXT SWITCH 810 White
i need a good PSU between 800W-850W
Temile
405
I have a 2600k and GTX 570 (which draws more than a 670) running on a 460w power supply. It actually draws only 270w. If you oc and sli, you may need 700w just to provide room for capacitor aging (my sig rig uses about 500). What is your budget?
I have the Switch 810 (black). It's a nice case, but a little hard to move around and a little plasticy. The top panel that can slide open and closed is fragile and seems like a gimmick--I don't like leaving it open for fear of things falling in. I'd get the HAF if I did it again (I have a Storm Trooper and its awesome, but even bigger than the 810).
Temile
405
If you have the budget, the Seasonic X-650/X-660 will also work. My sli system with 3930k was running on an X-660 quite comfortably until I added a 3rd gpu.
Nsync
62
i prefer it to be Modular & has OVP/UVP/OPP/OTP/SCP/OCP, to be safe
what do you think for the COOLER MASTER Silent Pro Gold Series 800W?
yeah, i was worry about top louver, they had to put filter in the top, i don't know anything about Storm Trooper, i'll check it now
Nsync
62
is 650W sufficient for SLI & OC ?
Nsync
62
i'll check the review now, thanks :)
what do u think for CORSAIR Professional Series Gold AX750
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139016&Tpk=CMPSU-750AX
OR
CORSAIR Professional Series HX750
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Nsync
62
thank you, but i have a question
why u refused cooler master? is there any issues in it?
