Help me!
Which will perform the best?
  • 460
    Votes: 0 0.0%
  • 560
    Votes: 11 78.6%
  • 4870x2
    Votes: 3 21.4%
  • Total voters
    14
devanwarner
34
Any recommendations on which 7870?
Sorry, I got out of the pc part loop. I got into android real bad, but im back to pc gaming. I miss it<3
andrewcarr
He mentioned $350 as the max so I didn't want to go above that but if you do have the extra $10-20 these ones are also very nice.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125418
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102983
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127662
By no means am I saying that the $350 sapphire is bad but these ones should just be slightly better. For example if you don't plan on overclocking (voids warranty) the Gigabyte card is overclocked to 1100mhz vs the 1000 stock rate. This can easily be achieved on the others but doing so will void the warranty.
andrewcarr
ricardois
1,470
YES CF is different performance, if the cash is so close like that, go with the single card solution, there will be a lot of problem you will run into if you are using crossfired cards, some games will not get so much performance, other games will only work with 1 card properly, etc, single card solution is always the way to go, unless you can go with a much lower price, or if you've had a single card and wan't only to increase its performance instead of buying another gpu.
The 560-448 is a "broken" 570. Take a 570 that failed testing with a bum SM or disable 1 SM on a 570 and what ya buying is a 560-448.
Nice combo...I'd check to make sure that the memory kit is supported by my motherboard. If not, I don't think the egg would allow returning just the memory kit. :cry:
Also, note that the card is NOT a 560Ti or a 560Ti 448. It is a plane 560.
devanwarner
34
Plain* ;)
and yes it does. I saw that its a plain one. nbd though, i don't mind. thats a great deal.
andrewcarr
I have the best idea instead of getting more memory that you don't need, as long as you currently have at least 4GB, (that comes with an overpriced card, card $150 with $45 of memory) then get the 6850 for $250.
