Help me
amadlopes
Please help me. I need to set up a computer to run 4 dvd/mpeg videos at the same time each video on a monitor.
Do you know if it is possible to do that on a Matrox QID or on a Colorgraphic Xentera ? Wich is the best to do that ? Is there any better way to do this ?
Thank you,
Afonso
Citrino
I know that Matrox cards can display on 3 monitor. But Do you need to have the full audio for each video?
Because, if you need 4 video output + 4 distinct audio output, you wil probably have to buy a solution that will cost you a lot of money!
It's tricky to use words like <b><font color=green>AMD</font color=green></b> or <b><font color=blue>Intel</font color=blue></b> in a signature some users could think your are biased.
The Matrox QID is based on the G200/400 chips (the QID PRO uses a Parhelia Chip), the Xentra is based on the R9000 (2 for 4 monitors 4 for 8, IIRC), your issue will not be the cards so much as the programs outputing the video. Mpeg with the right player shouldn't be a problem I often play multiple video on dual monitor, however I cannot open 2 DVDs at the same time even if I run them off the harddrive. I use Power DVD, ATI's Media Player, MS MediaPlayer 9 (no need to test out 10 yet [not enough feedback]), and ZoomPlayer; and none will do simultaneous DVD playbacks. Likely a player restriction, not encryption issues because even stripped DVDs do it.
So it is possible to do multiple videos, but I'm not sure about DVD itself, likely possible, but you may need to find a special program. If you can get 4 instances playing you should be able to display them on each separate monitor.
I think your issue will be more software related than Hardware. Contact Colorgraphic or Matrox directly and they would be able to tell you what programs they know of that support that feature for their products.
ALSO, 4 uncompressed DVDs simultaneously is alot of info to process, you would likely need a SCSI or at least ATA Raid array to handle that.
- You need a licence to buy a gun, but they'll sell anyone a stamp <i>(or internet account)</i> ! - <font color=green>RED </font color=green> <font color=red> GREEN</font color=red> GA to SK :evil:
<P ID="edit"><FONT SIZE=-1><EM>Edited by TheGreatGrapeApe on 07/14/04 12:26 PM.</EM></FONT></P>
