Approximate Purchase Date: This week
Budget Range: 250$
System Usage from Most to Least Important: Low gaming performance, everyday use.
Parts Not Required: Keyboard, mouse, monitor, OS, video card, hard drive and optical drive.
Preferred Website(s) for Parts: newegg.com
Country of Origin: United States
Parts Preferences: None
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1024x768, 1280x1024
Additional Comments:
Mobo: BIOSTAR A770E3 AM3 AMD 770 ATX AMD Motherboard
Power Supply: Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
RAM: Wintec AMPX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model 3AXH1333C9WS4GK
CPU: AMD Athlon II X3 445 Rana 3.1GHz 3 x 512KB L2 Cache Socket AM3 95W Triple-Core Desktop Processor ADX445WFGMBOX
Case: APEX Vortex 3620 SGCC / ABS ATX Mid Tower Gaming Computer Case
This is what I have so far. I'm using this as a low gaming performance rig for a game that will be coming out soon called Red Orchestra: Heroes of Stalingrad (Enhanced Unreal Engine 3 game which I will be running on a Radeon HD 4670). The hard drive is from a Dell Dimension 9100, which has a P5 molex connecter and a SATA connector. It has Windows 7 32 bit installed so I'm wondering if this would be compatible with the rig? Also are all the parts compatible or is there something that needs to be change? Please leave feedback, comments or tips. Thank you.
Budget Range: 250$
Overclocking: No
