[SOLVED] help, my pc isnt booting, no post screen.
Natrium
42
I dont know in which category to place this in but anyways. I recently built my computer, and when i turned it on, the cpu fan started, all the rgb started, but the case fans didnt spin at all, CMOS lights red on VGA, DRAM, CPU, BOOT. No post screen or anything.
System specs? Double check all your power connections, from source and to board to start with.
CPU: Ryzen 2600
GPU: RTX 2060 6GB Z Gaming
Ram: Vengeance Pro 2x8 gb 3200mhz rgb
PSU: Corsair 650 watt semi modular bronze rated
Cooler: Arctic Freezer 34
Mobo: B450 Aorus Pro
Case: NZXT H500
HDD: Seagate barracuda 1TB
SSD: Kingston A400 240GB
I've checked everything ill do it again for you, just try to push on everything right?
CPU: Ryzen 2600
Case: NZXT H500
I would pull out and reseat that way you know it has been double checked.
