Fan comes with 2 cables, one for power (molex/3pin support), another presumably the RGB whatsamathingy (male and female tips), that plugs either to a RGB remote or a whatsamdoogle header on the motherboard.
The Aurus has a few presumably whatsamadoogle headers on the motherboard, but the mobo manual only references RGB strips installation and nothing about RGB fans.
Can I plug the fan RGB female tip into the male whatsamadoogle header on the motherboard directly?
See below excerpt from the mobo manual:
And the cable with the whatsamathingy at the end (female)
Your help in solving this mystery that has been plaguing me would be greatly appreciated.
