HELP!!!!!!!!! needed for a prebuilt system.
arslankhalid
51
i am buying a pc from cyberpower that i have customized myself and i just wanna know if it will play every game out there at highest settings. resoluton 1900 . 1080. any help appreciated. i am paying 1900 dollars for it.is it worth it.and dont tell me to build ur own.
CAS:Azza Hurrican 2000 Full Tower Gaming Case with 4 Hot Swappable HDD Cage & (4) 230MM Fans
CASUPGRADE:12in Cold Cathode Neon Light [+10] (Red Color [+0])
CD:LG UH12LS28K 12X Blu-Ray Player & DVDRW Combo Drive [+41] (BLACK COLOR)
CD2:None
COOLANT:Standard Coolant
CPU:Intel® Core™ i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified)
CS_FAN😀efault case fans
ENGRAVING:None
ENGRAVING_MSG:
FA_HDD:None
FAN:Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
FLASHMEDIA:INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOR)
FREEBIE_CU:FREE! Mass Effect 3 Game [+0]
GLASSES:None
HDD:500GB SATA-III 3.0Gb/s 16MB Cache 7200RPM HDD [-17] (Single Drive)
HDD2:None
IEEE_CARD:None
IUSB:Built-in USB 2.0 Ports
KEYBOARD:Xtreme Gear (Black Color) Multimedia/Internet USB Keyboard
MEMORY:8GB (2GBx4) DDR3/1600MHz Quad Channel Memory (Corsair or Major Brand)
MONITOR:None
MONITOR2:None
MONITOR3:None
MOTHERBOARD🙁3-Way SLI Support) ASRock X79 Extreme 4 Intel X79 Chipset Quad Channel DDR3 ATX w/ UEFI bios, XFast LAN, Charger, & USB Technology, 7.1 HD Audio, GbLAN, USB3.0, SATA-III RAID, 3 Gen3 PCIe X16, 2 PCIe X1 & 2 PCI
MOUSE:XtremeGear Optical USB 3 Buttons Gaming Mouse
NETWORK:Onboard Gigabit LAN Network
NOISEREDUCE1😛ower Supply Gasket [+5]
NOISEREDUCE2:Anti-Vibration Fan Mounts [+9]
OS:Microsoft® Windows 7 Home Premium (64-bit Edition)
OVERCLOCK:No Overclocking
POWERSUPPLY:1,050 Watts - Corsair HX1050W 80 Plus Power Supply - Quad SLI Ready [+166]
RUSH:NO; READY TO SHIP IN 10~15 BUSINESS DAYS
SERVICE:STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS:None
TEMP:None
TUNING:None
TVRC:None
USB:None
USBFLASH:None
USBHD:None
USBX:None
VIDEO:NVIDIA GeForce GTX 680 (Major Brand Powered by NVIDIA)
Yeah, you don't need water cooling for a non-OC CPU. You will never get it hot enough to make air cooling insufficient. Hell, I use air for my OCed I2500K and it never gets too hot.
1050W is definitely overkill unless you plan on getting another GTX680 to SLI.
Lastly, check out Tom's CPU recommendations. You can get away with a I2500K, which hits the sweet spot for performance and OC-ability and you can save a lot of cash.
In fact, Tom has the builder's guide right now, check it out and see what they throw in there.
Good luck.
Water cooling for a non-overclockable chip? Go with one of the 3570K/3770K builds.
1050W is overkill for a single 680. 750W is plenty.
Get one of the Intel smart response technology drives to boost HD performance.
Good luck.
