Question Help needed. Upgraded system, experiencing frequent reboots and other crashes.
Aug 4, 2024
13
Hello,
I recently decided to upgrade my old 9600k to a ryzen 7 7700x. Swapped motherboard, ram, and cpu cooler as well. Continued to use my 3070. I initially booted to my old windows install to download my motherboards BIOS update. Once that was done I performed a fresh install of windows, wiping my OS drive and installed all the necessary drivers.
I have been experiencing many frequent crashes, especially in games but also while idling. I have been at it for several days now and I fear no amount of googling will help.
I have upgraded my PSU to an 850W gold certified model from Corsair, and my RAM, also from Corsair (16gb) with no improvement.
The crashes are generally reboots, black screen followed by the computer booting up again. But have also had games crash such as Xdefiant, which simply close and give me the crash report page at which point the system remains on, although it will also occassioanlly force a reboot.
Some games like RE7 always cause a reboot after about 3 minutes of running.
Sometimes it crashes mere minutes after booting up. Other times, I have sat in a discord call for over an hour without it crashing.
I have only had one BSOD with error IRQL_NOT_LESS_OR_EQUAL.
I have reseated my GPU and CPU. All fans are working. Visually, there is nothing wrong in the case.
Any help would be appreciated
Specs
Ryzen 7 7700x
MSI PRO B650-P Wifi
RTX 3070 Aorus
Fuma 3
16gb DDR5 Corsair Vengeance 2x8
Corsair RM850X 850W PSU
Samsung 1tb SSD (from old system)
Seagte 2 TB HDD (from old system)
Hello,
Specs
Ryzen 7 7700x
MSI PRO B650-P Wifi
RTX 3070 Aorus
Fuma 3
Check RAM.
Go into BIOS and make sure DRAM voltage is set to 1.25V.
If that doesn't fix crashes, then you can also set Command Rate to 2T.
I've looked around in the BIOS but can't find the setting. Any idea how I can change the command rate?
Edit: Command rate also does not appear in CPU-Z
Somewhere in advanced ram configuration section.
Should be together with DRAM latency configuration.
I'll give it a shot later tonight, thank you
other things to try
update your bios to latest version some corsair ram needs a bios update to function properly
infact that board have several bios updates for better ram compatibility.
also if your using windows 11 turn off
Hardware-Accelerated GPU Scheduling
this can be found in settings/display/graphics.
this solved several crashes in games it seems to effect nvidia gpus more.
Swapped motherboards, crashes continue. RMAing with AMD. Had an idea, only thing I havent thought of doing.
Thoughts on swapping my OS to a different drive? I'll give it a shot anyways when I get the chance.
Reactions: helper800
