Hello Tomshardware community.
I wanted help regarding the right DVI cable i should use to connect my graphics card and my Monitor.
My monitor is LG w2243t - 21.5" Full hd 60 Hz monitor having a 1 DVI-D port and my graphics card being Sapphire Dual-x R9 270x .
Off lately i heard that VGA is horrible when it comes to gaming , also it results in loss of image quality , i thought i shud just start using the DVI port i have on my monitor.
Also DVI and HDMI are nearly the same for 1080p 60 Hz monitor i wont be gaming at 4K , neither do i require audio to go along with video so DVI is fine.
I'm just confused between the DVI-I , DVI-D - DVI ports and cables , good lord there are so many.
So my question is :
Which cable do i require to make it work ? considering my graphics card and monitor.
IF you can please provide a link from where i can purchase , i stay in India and can order stuff online , so if you guys could please provide such links.
If not i ' m okay with the international links you post from amazon,newegg !
See these are the images.
for my monitor's port
http://s27.postimg.org/5fqn6z69f/LG_W2243_T_PF_6.jpg
and this for the graphics card port for DVI input :
http://media.sapphiretech.com//images/prods/2037/11217-01_R9_270X_2GBGDDR5_DP_HDMI_2DVI_PCIE_C03_635161492389260477_600_600.jpg
Thank you !
So my question is :
Thank you !
