[SOLVED] Help on first PC build
Nov 29, 2019
9
Keep it to 1 thread
Build
Can anyone please check over my PC build, and if I should change everything. I will only be playing games on 1080p and I will be upgrading the storage and CPU cooler at a later date.
G-skill trident Z neo is made for Ryzen, so it should be compatible. After some thought, I would probably spend the little bit extra, and get a Seasonic PSU, instead.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($189.99 @ Amazon)
Motherboard: ASRock X570 Steel Legend WiFi ax ATX AM4 Motherboard ($194.99 @ Amazon)
Memory: G.Skill Trident Z Neo 16 GB (2 x 8 GB) DDR4-3600 Memory ($99.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($99.99 @ B&H)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card ($399.00)
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case ($109.99 @...
Made a few changes. Faster WIFI, better quality PSU, faster ram, and less expensive storage.
Motherboard: ASRock X570 Steel Legend WiFi ax ATX AM4 Motherboard ($198.98 @ Newegg)
Memory: G.Skill Trident Z Neo 16 GB (2 x 8 GB) DDR4-3600 Memory ($89.99 @ Newegg)
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case ($109.99 @ Amazon)
Power Supply: Thermaltake Toughpower Grand RGB 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($98.98 @ Newegg)
Case Fan: be quiet! SilentWings 3 PWM 50.5 CFM 120 mm Fan ($25.90 @ Amazon)
Total: $1212.82
Generated by PCPartPicker 2020-01-17 09:54 EST-0500
Reactions: Archaic59
Total: $1212.82
Does this matter
  • Note:The ASRock X570 Steel Legend WiFi ax ATX AM4 Motherboard has an additional 4-pin ATX power connector but the Thermaltake Toughpower Grand RGB 650 W 80+ Gold Certified Fully Modular ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it.
Can anyone help me with this PC Build, I am wondering if this Ram is compatible with this motherboard, and if there is any other changes I should make to this build.
PCPartPicker Part List: https://pcpartpicker.com/list/3qstQq
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: Thermaltake Toughpower Grand RGB 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($91.99 @ Amazon)
Total: $1191.84
Generated by PCPartPicker 2020-01-19 18:07 EST-0500
Power Supply: SeaSonic FOCUS 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($104.99 @ B&H)
Total: $1224.84
Generated by PCPartPicker 2020-01-20 09:33 EST-0500
Reactions: Alexferro1
