Help overclocking Q6600 to 3.8+ with lower voltage
TehPwn
56
Hey all, thankyou for taking interest in my thread, I am looking for some general help and tips on how to overclock my Q6600 to 3.8GHz or higher for benching at a lower voltage.
I will start by listing my hardware:
Gigabyte X38-DS5 DDR2 Motherboard
8 GB OCZ Reaper @ 1035MHz 5-5-5-15 (2.35v)
OCZ GameXstream 700w PSU
250GB, 320GB Seagate Hard Drives
Q6600 @ 3.72GHz 1.325 VID (1.7v) LOL! Temps: 34,34,35,36! - Weird!
ATI Radeon 3870X2 @ stock
Sound card etc.
Ok, what I am obviously concerned about is my crazy voltage on the CPU (1.7v) and the fact that my temps are so low! I have left all other voltage settings on Normal as they don't seem to make any effect when using lower voltage, but I will list the options in my BIOS available and what I have them on:
CPU Voltage: 1.7v Frequency= 3.72GHz 9.0x Multiplier
FSB= 414MHz 9.0x
PCI-E Frequency: Auto
C.I.A.2: Disabled
Performance Enhance: Standard
RAM: 1035 5-5-5-15 2.35v - (voltage too high) - My motherboard has a habbit of automatically lowering the default voltage to 1.8v from 2.2v
Advanced RAM timings: Auto
DDR2 Voltage: 2.35v
PCI-E Voltage: Normal
FSB Overvoltage: Normal
MCH Overvoltage conrol: Normal
MCH Referance voltage: Normal
DDR Referance voltage: Normal
DDR2 Termination: Normal
Load Line Calibration: Enabled!
VID: 1.325V
Idle temps: 33-37c on all 4 cores.
- These are all the BIOS settings I have for tweaking etc, there may be an advanced menu? But I would really like some help at getting my CPU to 3.8GHz+ at a much lower voltage if I can, or is it just a bad CPU? I have not Orthosed the CPU at these settings yet but it seems to be stable in Games and Benchmarks etc, thankyou for your help! - Alex.
Anyone? I am using voltages higher than that of what a B3 requires lol, is it my board? Or am I just not doing it right Thanks.
Sounds that you are too right.LOL.
Sound damn nice to have those temps at such high voltage.
I might left out something but everything seems good.
Sounds wierd
Which software you are using to ckeck your temps??
What is your ambient (Room) temp ??
Its your Chip, not stepping. You have the Worse VID possible for a q6x00 series. That means your Chip starts as high as possible for a g0.
As you near upper voltages and speed, your chip will automatically need more VCore to be stable, because the VCore becomes less efficient as you raise it.
For instance my G0 1.3250 VID chip needs 1.440 Loaded to opporate at 3.6. (Modifying the GTL refs and junk relinquished the same speed at 1.420 VCore loaded.)
So, besides for high voltage anyways, you'll need a new chip to change that! Damn intel stripping their low VIDs from retail boxes! You have a much better chance at a OEM chip, because its possible that the OEM bought 100,000 a year ago or more, before intel was hip to the VID mattering to us OCers.
--Lupi
Humm, with my 1.325 Lupi I need 1.6-1.65v just for 3.65GHz! Now surely thats not right, as my temps are so low I do not mind going for high voltages, what should I increase in order to achieve 3.8ish with a voltage lower or around 1.7v lol Thanks.
Already know the values of your VDrop and VDroop? If not, boot at factory VCore setting, (The VID) Then load windows and note CPUz's idle violtage. The difference will reflect your initial VDrop. Then test with Prime 95 small ffts for 1 minute, and note the now lowered VCore voltage in CPUz.
Once you get to know those two, you can directly target a VCore voltage without having to look! Also, does your mother board support any version of Load Line Calibration?? That needs to be on big time when testing that high.
--Lupi
Yes it suppoprts Load Line Calibration thankfully, the Vdroop is not much about -0.10 or something, and whats VDrop? Humm, could it be my board at fault? Lupi whats the highest voltage I could put through my chip without it dying on me in a monthor so? Thanks.
At 1.7v, you're risking instant burnout regardless of temperature. It's not just a matter of lower lifespan, the chip can go at any minute. Tune it back down. :na:
It's strange you'd need such high vcore just to reach 3.72ghz. My VID 1.3125 q6600, which is almost as bad, run at 1.65v for 4ghz, one hour prime95 stable. Didn't test for more than 1 hour, 1.65v is too hardcore for me. 😛
Ahhh! LOL! All this is annoying me now! Ha OMG Dagger you have nearly the same motherboard as me (mine is the DS5 version) So what settings did you use in BIOS to get to these settings? Ha maybe we can get somewhere with this?!? Thanks.
The only thing that's off is PCIE clock. You didn't lock it at 100mhz. Overloaded graphics card can cause loss in stability.
The ram voltage is higher than I'd think is safe, but up to you. 😛
I had no problem running it at stock chipset voltage, but it doesn't hurt to try higher.
Humm, MCH doesnt seem to have any effect with me LOL! By how much? I have put as much as + 2.25 through but still no luck LOL! Could my board be faulty?
Then it's not the chipset voltage. There is no way x38 requires such high voltage for that tiny overclock. Remember, it runs at 1600mhz fsb stock.
So you left everything on Auto except PCI-E Frequency? I just set that to 100 with FSB Voltage increased by .1+ and MCH increased a little and it would even boot into Windows with a 1.65 voltage, IMO what next? Should I get a new board? Thanks.
I use a 700 watt tough power on my 3.8 OC, so prolly not. Its more than likly the VID of your chip. Its just to high, because there is a sliding scale at work. From 3.6 to 3.8 takes an exceptional amount of VCore to stay prime stable. As a matter of fact, thats the first q6600 I have gotten 8 hour stable, and its a 1.2500. So I get like 16 extra VCore notches you dont, and that alone makes it perform better. The more VCore you add, the more it needs.
And then at 3.5 on a 1.3250 you encounter the High VID syndrome where it takes an exceptionally large ratio of VCore to speed gains where it doesnt make it worth it. If it starts high, it will need to go much higher. Odd, but thats how it works.
I only know it because I tested 10+ q6x00s myself.
--Lupi
Oh, I notice that at 1.2625 the syndrome is minimal up to 3.6. My 1.2750 one reflects the high VID syndrome right before 3.6. My 1.2500 that I tested at the 3.8 showed it at like 3650.. so that means my 1.200 shouldnt encounter it until around 3.7ish. So I may get 3.9 on it!
Weeeeee!
--Lupi
Humm interesting VID stuff! Thanks Lupi! But hey evenm Dagger said he had a 1.3125 VID and only needed 1.65v for 4.0GHz for a quick bench etc! I need 1.65v for just 3.65GHz, now surely his VID cant be that much better than my 1.325v one, his is the next worse one! So what should i do? LOL
Oh, I dont mean for a bench. I meant to actually be prime stable for hours. I could prolly fake a bench at 4.0 or so at the same VCore value.
--Lupi
LOL! So is it not impossible to get 4GHz on a 1.325v VID or is it? I mean I don't mind going to around 1.6-1.7v if needed, but I just need to know if a 1.325 VID would completely stop me from getting 3.8GHz or above??? Im starting to think the problem is more motherboard related??? Thanks for your help so far! - Alex.
