Question HELP PC FREEZES AFTER 10-15 SECONDS
danzelation031
20
My PC is unstable thats why I manually set frequency 3.6ghz and voltage into 1.2. After installing Windows10 I tried making frequency and voltage set to AUTO but now it freezes. If I boot to BIOS its still freezes after 5-10 seconds. I also tried clearing the CMOS, removing the battery and still it freezes after 5-10seconds. I also tried removing 1stick of ram and using only 1 stick but there's no luck. Can you please help me fix the problem?
SPECS:
Ryzen 5 3600
Asrock B450m Steel Legend (Latest BIOS)
16gb TForce Ram
RTX 2060
Thermaltake Smart SE 630w
Now its stuck here.
SPECS:
Ryzen 5 3600
16gb TForce Ram
RTX 2060
Now its stuck here.
Can you go to Safe Mode? Try System Restore
Now my pc wont show display. I tried different PSU but still there's no display. Now I think its a dead CPU or mobo but if its motherboard the lights effect that I sync with rgb is still the same its not reset or whatsoever.
