Hi, I'm trying to add new ram to my PC from 32GB to 64GB. When I add in the new ram, my PC won't start and the RAM status LED light on my motherboard lights up indicating it's not working properly. I have no idea what to do to fix this. I am trying to utilize the 64GB of ram for rendering purposes. I bought the 64GB of RAM after I tried to render with 32GB of RAM and it failed. Slightly panicking because of deadlines and 32GB ram is not enough to render with.
Current build:
Tower: Antec Eleven Hundred Performance Gaming Case XL-ATX (https://www.amazon.ca/Antec-Eleven-Hundred-Super-Computer/dp/B005X3E4YC)
Power Supply: Corsair RMx Series RM850x 80 PLUS Gold Fully Modular ATX Power Supply (https://www.canadacomputers.com/product_info.php?cPath=33_442&item_id=119737)
Ram: 2 of G.Skills Ripjaws V Series 32GB (2x16GB) DDR4 3200MHz (https://www.canadacomputers.com/product_info.php?cPath=24_311_1326&item_id=099478)
CPU: AMD Ryzen 9 3900X 12-Core (https://www.canadacomputers.com/product_info.php?cPath=4_64&item_id=138211)
Motherboard: Gigabyte x570 Aorus Pro Wifi Motherboard (https://www.canadacomputers.com/product_info.php?cPath=26_1832_1833&item_id=138842)
GPU: ROG Strix Geforce GTX1080Ti (https://www.asus.com/ca-en/Graphics-Cards/ROG-STRIX-GTX1080TI-O11G-GAMING/)
2 Monitors: Acer Predator XB240H (https://www.bestbuy.ca/en-ca/produc...gaming-monitor-predator-xb240h-black/11183997)
Operating System: Windows 10 Home 64x bit
Current build:
