Hi there,
Last week I went to turn my comuter on (which was running a gtx1050 at the time), to which I discovered that it would not boot. The system had been working fine for a year before but when I turned it on there was no beep from the motherboard and no display whatsoever ( not even the bios screen ).
So I tried resetting the CMOS by taking the battery out for 15 seconds, but it still wouldn't work. I also tried uninstalling all of the display drivers using DDU before putting the card back in but it still didn't work.
After testing the other components in my system, I finally decided that the gtx1050 was broken and put my old AMD Radeon R7 250 back in - which worked.
I ordered a gtx1650 super to replace the card and when I put it in the system, it did the same thing as the 1050.
I am currently using the r7 250 to use my computer to write this post and it works fine but it won't even output a display with either of my NVIDIA cards.
Any suggestions would be greatly appreciated
My specs are:
CPU: AMD Fx-4300 Quad Core
GPU : Currently AMD R7 250 - ( the gtx1050 and gtx1650 super would not boot).
PSU - 550 Watt
Memory - 2 x 4gb DDR3 Kingston HyperX
Motherboard : Gigabyte ga-78lmt-usb3
My specs are:
PSU - 550 Watt
