i turned on my Pc and a load Bang came from it! i dont know much about Pc's but when i checked the back of power supply theres a switch where u can change the voltage from 230/110, mine was on 110 and when i plugged in the power lead...BANG!
The killing thing is it's or was brand new and i cant return it cos it came from America. Can someone please help me and tell me what i need to get or whatever?
Yes i know im stupid.
Specs...
Intel Core 2 Duo E8400 3.0Ghz Processor
Asus P5N73-AM Motherboard
nVidia 7050 Chipset
4GB DDR2-800 Dual Channel Memory (2x2GB)
Western Digital 500B SATA-II Hard Drive
20X DVD-RW Burner w/Lightscribe Technology
nVidia 9800GT 512MB GDDR3 Video Card
PhysX Support
DirectX 10 Support
22-in-1 Flash Media Reader
RAID 0/1/0+1/5 Capable
Integrated 10/100 LAN
4 x USB 2.0 Ports (Expandable to 8)
(1) PCI-e x16 / (1) PCI-e x1 / (2) PCI
8 Channel High Definition Audio
Clear Side Panel
580 Watt Power Supply
Vista Home Premium 64-bit
Specs...
nVidia 7050 Chipset
PhysX Support
DirectX 10 Support
Clear Side Panel
