Question Help please
Jun 18, 2021
25
Hello, i am having a problem with downloading on steam. Ever since i built my PC my steam downloading was going very slow. Whenever i download using other launchers, my speeds are Fine, but steam just does'nt work.
I have watched videos, and none seem to work, so i come here for support. The download speed is increasing and dropping in consistent patterns, and normally is at 40-50 KBs. The disk usage seems fine, but the network usage is bad, and it seems to gbe affecting the disk usage.
Check that your hdd/ssd (wherever you store your downloaded files) aren't (close to) full.
Have you tried the steps suggested here ?
I think the problem is that my HDD is almost full. 80GB left, so might be that. THank you for the help and i'll let you know if making space helps.
