Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
I can`t find out exactly what the working temp of an AMD Athlon XP
3000+ should be. Can anyone please help. At the moment it is running at
40C / 104 F with a Coolmaster Aero 7 Lite fan fitted to it.
That's the right temp. My 3500+ is running the same temps.
"Cyberdog" <david@INVALID.co.uk> wrote in message
news:js1bs0h5ovqv1pnt36b5ua39h5gv6on1rf@4ax.com...
> Hi,
On Sun, 19 Dec 2004 13:54:46 +0000, Cyberdog wrote:
> Hi,
> I can`t find out exactly what the working temp of an AMD Athlon XP 3000+
> should be. Can anyone please help. At the moment it is running at 40C /
The working temp info is all readily available at the AMD website, had you
looked properly.
