HELP! Problems with ATI TV Wonder Pro
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I’m hoping someone here can help me. I recently bought an ATI TV
Wonder Pro pci editoin w/o remote, and I cannot get the software to
run. The drivers installed on my windows XP machine, and ATI’s
multimedia center incorporated Television as an option. But every time
I open the program it crashes or does not respond at all.
Is there a known compatability problem with any other ATI cards? I
have an AGP 8x Radeon 9600 w/128 MB RAM ... Which made me think that
the install would go smoothly. I call ATI, but their number is always
busy and I work during the hours they are open.
Can anyone here help address my problem? I’d be very grateful. 😀
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/ATI-HELP-Problems-TV-Pro-ftopict59702.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=302069
"Decoder_X" <UseLinkToEmail@HardwareForumz.com> wrote in message
news:7_302069_fd4fa28793ed225afb4a3bd3860ae654@hardwareforumz.com...
Try adding this to your path.
Right click My Computer > Properties>Advanced>Environment Variables, click
bottom box, select Path, click on Edit button. Add to end of existing path
data ";%SystemRoot%\System32\drivers" without the quotes.
It could also be a corrupt or missing codec.
Rob
"PhxGrunge" <noname@qwest.net> wrote in message
news:s8aHe.10$Va4.4514@news.uswest.net...
>> I'm hoping someone here can help me. I recently bought an ATI TV
>> run. The drivers installed on my windows XP machine, and ATI's
> path data ";%SystemRoot%\System32\drivers" without the quotes.
> Can anyone here help address my problem? I'd be very grateful. 😀
> request
> Topic URL:
The issue is unlikely to be compatibility related, more likely installation
technique related. These things have to be installed in the correct order
with all the correct modular components in a very disciplined manner. For
example if you attempt to install MMC before rebooting from the driver
installation or attempt to run MMC before rebooting after its installation,
that's just asking for trouble. Additionally if there are any background
applications running at the time of installation that can also cause
problems. There are instructions for installing the software for the TV
Wonder Pro on ATIs website also www.rage3d.com forums are a good source of
help for this sort of thing.
What order was everything installed in (and using what components/drivers)
also, any error messages generated?
Paul
If you have DirectX9.0c installed and do not have any red X or yellow ! in
Device Manager try doing a repair install of MMC in the Add/Remove Programs
App. I've had to do a repair or reinstall on the last two versions of MMC to
get them installed properly. What version are you using?
Running the PC Check in the Configuration program may give a clue. It's not
the best program but occasionally it's helpful.
> message
> ATI TV
> software to
> ATI’s
> every time
> cards? I
> think that
> is always
> Variables, click
> existing path
> data ";%SystemRoot%System32drivers" without the quotes.
That did not affect anything. I followed your instructions perfectly,
but to no avail. The TV program still does not respond to my efforts
to open it, and Easyshare TV still crashes on startup.
I recently updated all the ATI drivers. All my software is current. I
filed a support ticket with ATI a while back, but still nothing. I
have another 7 days before the return policy is void ...
If I can’t get this thing to work before then, do any of you have
favorite picks for TV cards? This whole experience is putting a bitter
taste in my mouth for ATI products.
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=302411
> message
> ATI TV
> software to
> ATI’s
> every time
> cards? I
> think that
> is always
> grateful. 😀
> yellow ! in
> Add/Remove Programs
> versions of MMC to
> clue. It's not
It looks like I have ATI MMC ver. 8.2.0.0 AS WELL AS 9.08. I’m
removing 8.2 as I key this, and I’m going to run a repair install on
9.08.
And, cross your fingers ...
Well, unfortunately, its still a no-go. Any other suggestions?
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=302650
"Decoder_X" wrote:
> It looks like I have ATI MMC ver. 8.2.0.0 AS WELL AS 9.08. I'm
> removing 8.2 as I key this, and I'm going to run a repair
> install on 9.08.
Here’s some additional information about the software I’m running.
Hope it helps ...
Catalyst Control Center version 1.2.2006.286
.NET Runtime Version 1.1.4322.2032
ATI Radeon 9600 driver version 6.14.10.6553
ATI TV Wonder Pro A/V Capture driver version - 6.14.10.8307
ATI TV Wonder Pro A/V Crossbar driver version - 6.14.10.8307
ATI TV Wonder Pro Tuner (Philips 1236 MK3) driver version -
6.14.10.8307
> install on 9.08.
have fun cause its a bich. ive owned my AIW ati 9700pro now 2 years
and have always had asome kinda problem with this sux software some
version of mcc do not run with some versions of the gfx driver.
or u get it working but cant save tv recordings to only the c drive,
or theres no a udio, etc etc. currently im back to cat 5.4 driver
using mcc
9.06.01 but this still only allows saving recordingd to you C: drive
wish they’d fix this.
> years and have always had asome kinda problem with this sux
> software some version of mcc do not run with some versions of
> the gfx driver.
> drive, or theres no a udio, etc etc. currently im back to cat
> 5.4 driver using mcc
> drive wish they'd fix this.
So, if I were to downgrade my driver version it would work? What
combination of outdated ATI software would make this thing work?
