[SOLVED] Help!! PSU Question About My System
Slayer282498
Hey guys need some help i have a basic single 120mm sized radiator liquid cooling block for my cpu. i have a i7-7700K and 2 ssds 2HDDs looking into getting an Nvme ssd and i want a gtx 2070. i need help guys i only have a 500w coolermaster power supply. Do you guys know if that will really be enough i dont want to overclock or anything. this is my power supply: https://www.pccasegear.com/products/42285/cooler-master-mwe-500w-power-supply
Any help would be greatly appreciated im on a very tight budget and if my current psu isnt enough watts ill have to get a 2060 with a better psu instead. Cheers.
The cooler master masterwatt psus arent great quality. The RTX 2070 has a minimum psu requirement of 550 watts so i wouldnt run it on that low quality 500 watt. I would suggest a evga 650 g2 or seasonic gold 620w. What is your budget for a new psu?
Cheers guys and yeah i got like 800 850 tops and the nvme stuff is for later i just wanted to know if i can get a 2070 or a 2060 and a new psu because 2070 is 800 2060 and psu is 800 also so i can get one combo or the other
