Help rate and optimize my build for some love!
gaming- 8/10
recording -9/10
overall- 8/10
if you could maybe get a fx 8120 for a little bit of a boost and you may also want to get a good cooler such as a cooler master 212 evo or just a cheap arctic cooler
Thanks! But isn't the FX-8120 better for running things like VMs? I'm not completely sure but a few people say it's better for that then gaming. I also forgt to mention a aftermarket cooler will be installed maybe a week or two after the initial build.
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($59.99 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($24.99 @ Newegg)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Microcenter)
Video Card: Asus Radeon HD 7870 GHz Edition 2GB Video Card ($247.86 @ Newegg)
Power Supply: PC Power & Cooling Silencer MK III 500W 80 PLUS Bronze Certified ATX12V Power Supply ($49.99 @ Newegg)
Monitor: Samsung S22B150N 21.5" Monitor ($109.99 @ Newegg)
Keyboard: Logitech MK120 Wired Slim Keyboard w/Optical Mouse ($15.13 @ Amazon)
Total: $712.93
(Generated by PCPartPicker 2012-11-25 10:50 EST-0500)
No need for coolers if you don't plan to overclock.
This is better.
Friend owns the same PSU and says its fine.
Opinion? But I do prefer intel > AMD. But this is a budget/performance build.
Low profile heatsink >
Gigabyte > Sapphire and reviews say the extra money is well worth.
I would consider the i5 but I'm not to sure about a micro board in a full tower.
its fine but not the best. the xfx is a lot better. made by seasonic = pretty much the king of power supplies
it does perform better. just no overclocking. plus uses half the power of a amd chip and performs better at stock clocks
the intel stock is lower profile
sapphire is a better manufacturer. you got them mixed up.
My Thor V2 is coming in this Tuesday.
I will get that PSU is cheaper and you're right.
I'd love an i5 but I'd want a better mobo (and one that'd fit in my case with out wire-length problems(Thor V2))
I was talking about the heatsink on the RAM. I'll be getting a aftermarket cooler for the CPU anyway.
From reading reviews, people had more problem with the sapphire version of the card over the gigabyte. But if the Sapphire stays on sale, I might as well.
And @cute beans, is the Asus version of the card really worthy the extra money...?
the wire problem only comes from the power supply, not the motherboard
you can get a gigabyte z77x-d3h if you want for the motherboard
the heatsinks are pretty low
not really. i buy the one that is most acceptable in pricing. if the asus is not 229.99 after MIR, i wouldnt get it
