Help SP2 and IE6
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Please can anyone point me in the right direction to fix the
following prob.
2 days ago IE6 started to go intermittent when selecting links to
follow. Some links connect ok, but others don't, and the system
completely locks up requiring a re-boot. The problem is apparent
across all web sites, (and news groups) and it's the same links
on each occasion I try.
I have altered nothing on the system (wittingly) and disabling
firewalls, virus blockers and pop up disablers makes no
difference. The computer is only 4 months old, and I've had no
problems like this before.
What (or where) can I check and investigate. Frankly, I haven't
a clue.
Thanks for any help
Brian Bosley
the problem is that you have spyware and possibly adware. Get spybot search
and destroy. (www.google.ca search: spybot s&d
Ryan-EBK
"Brian Bosley" <bosbrian@ozemail.com.au> wrote in message
news:wIk4e.74$OV3.805@nnrp1.ozemail.com.au...
> Please can anyone point me in the right direction to fix the following
> prob.
> 2 days ago IE6 started to go intermittent when selecting links to follow.
> Some links connect ok, but others don't, and the system completely locks
> up requiring a re-boot. The problem is apparent across all web sites,
> (and news groups) and it's the same links on each occasion I try.
> I have altered nothing on the system (wittingly) and disabling firewalls,
> virus blockers and pop up disablers makes no difference. The computer is
> only 4 months old, and I've had no problems like this before.
> What (or where) can I check and investigate. Frankly, I haven't a clue.
> Thanks for any help
> Brian Bosley
Thanks Ryan,
Spybot found and destroyed 1 item in IE favourites, however it
has made no difference to my problem. I have also tried to
download Adaware but of course the links do not work. Is there
anywhere else I can look.
Thanks
Brian Bosley
"Ryan-EBK" <rkasteel@shaw.ca> wrote in message
news:edO4Q$XOFHA.2704@TK2MSFTNGP15.phx.gbl...
> spybot search and destroy. (www.google.ca search: spybot s&d
> Ryan-EBK
>> following prob.
>> to follow. Some links connect ok, but others don't, and the
>> system completely locks up requiring a re-boot. The problem
>> is apparent across all web sites, (and news groups) and it's
>> haven't a clue.
>> Thanks for any help
>> Brian Bosley
