[SOLVED] Help, system attacked by ransomeware
Aug 17, 2020
my system attacked by the ransomware malware and all of system files encrypted by the virus and they left the .txt note with ransom of $500 bitcoin currency to provide the tool so recover my all data. i have very important data which is encrypted/locked with extensions .lockbit .roger .pandemic. is there any tool i can recover my data. it is first time i had this type of attack and when i did my research about that they says it is "ransomware" attack.
Remember, even if you pay, you may not get your files back. The perpetrators are crooks and dishonest.
You may or may not have some options available.
For example:
https://www.easeus.com/file-recovery/recover-files-by-ransomware.html
You can find additional options by googling words such as "ransomware recover files".
However you must be very careful about the suggestions presented and any downloads in particular.
Do you have your data backed up? A clean Windows reinstall is recommended.
For example:
Latest posts
