Help upgrading older Lian-Li case
kyonic
8
Hey guys I have an older PC-60USB B2 Silver Aluminum ATX Mid Tower Computer Case. I have used the case for a couple of years and was wondering how I can upgrade it for better cooling. I was thinking of replacing the 80mm fans in it which it has 4 of them and they all have different speeds at which you can select them to run via the control on the front of the case. I was thinking of maybe getting a side window for the case and puting a 80mm or 120 blower fan on it to help. Or should I just uprade the 4 fans that are in there and leave it stock?
mkaibear
678
Why do you need to upgrade for better cooling? What kind of internal temperatures are you getting? You may find that clearing the airpath inside the case works a lot better than messing around with new fans, etc.
Latest posts
