[SOLVED] Help upgrading
eibelbilly
Proper
May 6, 2020
147
My system is a amd fx 6300, evga gtx960ssc 4gb, 8gb ram, on a msi sli krait edition., Call of duty warzone has random frame dips on anything above verry low settings what can I do to fix that.
My ideas where more ram from 8 to 32, a better gpu like a evga rtx 2060 ko and possibly a fx 8350 but are these worth it?
Going to a FX8350 depends on the motherboard you have. Many cheaper motherboards suffer throttling issues trying to run 125w CPU’s. Also a FX8350 is still way below a modern entry/mid level cpu. You really need to get off the old AM3+ platform if you want any reasonable improvement. Investing in an obsolete FX8XXX cpu and DDR3 RAM is a waste of money in the long term.
cod warzone random frame dips is cause on ur ram,but 32 is too much
16 would be enough
i suggest u go for ryzen 3 3300x/ ryzen 5 3600/x
16 gb 3200 mhz ram
with B450 tomahawk max
