Hello all,
I just started my career in game programming and we have to use pretty heavy stuff like the Unreal Engine where we have to compile the source quite a lot. This took a very long time (sometimes upto 5/6 hours) with my Ryzen 7 2700x CPU and so I've just upgraded my PC with a Ryzen 7 5800x CPU.
I'm using a stock Wraith Prism cooler for now as I'll need to save up some money for a better cooler and I've noticed immediately the temps are higher than my old CPU. For instance during idle, the temps range from 35 to 40 degree Celsius and when I open the file explorer it goes to around 50-56 degree Celsius. I don't think the temp should jump to 50 by just opening the explorer.
I also am seeing a feature called the "Curve Optimizer" and "Eco Mode" in Ryzen Master which I have no idea what it does. Could anyone recommend me good Ryzen Master settings for my CPU please? I'd prefer using the Precision Boost Overdrive as well.
My specs are: CPU: AMD Ryzen 7 5800x
Motherboard: Gigabyte X470 Aorus Ultra Gaming ATX AM4 Motherboard
RAM: 32 GB
Power Supply: Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply
Thank you
RAM: 32 GB
Thank you
