I need help completely overhauling my network system here, its outdated but also not set up or configured properly.
Im in the UK so my ISP (EE) has provided me a router, I've found with them that if its not the mater hub then you loose speeds and an operator for BT told me this is because using their own router they can monitor and optimise the speeds you get and without it they reduce your speeds, I can't say for sure that this is the case but its always been for me anyway.
Everything after that I want to change, I currently have the internet placed in the garage with an old mesh system spanning from it dragging the wifi through the house, however i have ethernet wired back to the garage from every room in the house, this currently isn't used as i don't have a network switch, something of which i could use guidance on which one to buy.
I also need advice as to if i should buy a new router and also which one, im going to guess that i will have to run this as a slave to the EE router provided by my ISP as to not be limited to speed. And finally is the mesh system i will use in the house, i want all the hubs used to be wired in to the network switch using the ethernet already intergrated in the house.
I should probably mention the speeds we currently get too which is 1gbps from a fibre line to the house.
Any suggestions or recomendations for user frinedly setups would be greatly appriciated.
Many Thanks
Many Thanks
