Question Help with BSoD. Ive tried pretty much everything
Mar 15, 2019
4
Hello. I am here because i get a constant BSoD when i try to install windows. It usually gets 4-22% but then the blue screen appears. I have updated my bios and kept the default settings. Here are my specs:
Ryzen 5 1600
RX 580 XFX 8gb
120gb Kingston SSD
500gb WD 5400 RPM HDD
1x8gb LPX Vengeance RAM
Thermaltake Smartseries 700W PSU
I forgot to mention i previously had windows 10 on another hard drive, and it was working perfectly fine, but then i installed the drivers for a wifi afapter and then i started getting the MEMORY_MANAGEMENT BSoD error. I decided a fresh install was the best choice since i had looked up every possible solution, tried it, and nothing worked. Now, as i try to reinstall windows on a fresh new drive, i get the SYSTEM_SERVICE_EXCEPTION error, which occaisionally says the problem file is Ntfs.sys. Does anyone have a fux for my problem? Keep in mind everythin in this build is brand new, not reaching over 1 month old.
Thread starter Similar threads Forum Replies Date
L Windows 10 1
Similar threads
