It has 5 ports that can be used for CPU and PCI-e. How many ports do you have in use for the CPU?But my psu has only two PCIE designated ports 2(8pins)
Either one of the five 8 pin sockets.How in wich do I connect power to gpu?
use the 600W PCIe 5.0 12VHPWR Type-4 PSU Power Cable
This cabel should be all I need to connect my gpu, right?And use this
Don't use the cable that comes with the GPU. It's a bulky solution that adds extra cables and connectors.This cabel should be all I need to connect my gpu, right?
Or should I use original connector that comes with ?
Thanks for help![]()
