help with CPU upgrade
littlea
4
hi all
i have an old machine (sony vaio pcg-fx150) and although it still works well, it's pretty slow at 733mghz (PIII). i'm looking for an alternative CPU to upgrade. the current specs of the PIII in it are:
socket 478
1.6Volts
24.6 watts
internal clock speed 533 mghz
anybody have any ideas as to finding something else that might fit (even if its only a little faster, say 1.0ghz)? TIA
a
EDIT: are you sure that you have a socket 478 mobo and a P3 on it? I guess P3's are socket 370 only.
that's what SONY told me anyhow and, if i remember correctly, i rean accross another website that said as much as well.
a
you most likely need a new motherboard
yes, that would be ideal. however, this is a notebook and i don't think that there are many options.
this same motherboard comes on SONY models that feature the 1.0ghz PIII but i don't know how to look for that CPU to purchase it, which is basically my question here. in sum, where can i find out what CPUs are compatible with my motherboard so that i can track down the fastest one?
a
I'm tired of posting links... to make sure Google for CPU-Z & download it... run it... it's a hardware detection software & it tells detailed info of your CPU.
k, ran it. it seems like right now it's running a Coppermine - 0.18µm mobile Intel Pentium III, BGA, micro-PGA.
what else do i need to know from there? i'm cutting and pasting results below
thanks!
here are the details:
CPU(s)
Number of CPUs 1
Name Intel Pentium III E
Code Name Coppermine-T
Specification Intel Pentium III E 750MHz
Family / Model / Stepping 6 8 A
Extended Family / Model 0 0
Brand ID 2
Package BGA/Micro-PGA
Core Stepping cD0
Technology 0.18 µ
Supported Instructions Sets MMX, SSE
CPU Clock Speed 745.2 MHz
Clock multiplier x 7.5
Front Side Bus Frequency 99.4 MHz
Bus Speed 99.4 MHz
L1 Data Cache 16 KBytes, 4-way set associative, 32 Bytes line size
L1 Instruction Cache 16 KBytes, 4-way set associative, 32 Bytes line size
L2 Cache 256 KBytes, 8-way set associative, 32 Bytes line size
L2 Latency 0
L2 Speed 745.2 MHz (Full)
L2 Location On Chip
L2 ECC Check enabled
L2 Data Prefetch Logic no
L2 Bus Width 256 bits
Mainboard and chipset
Motherboard manufacturer Sony Corporation
Motherboard model PCG-FX150K(UC),
BIOS vendor Phoenix Technologies LTD
BIOS revision R0211U0
BIOS release date 03/13/01
Chipset Intel i815EM rev. A1
Southbridge Intel 82801BA (ICH2-M) rev. 03
Memory
DRAM Type SDRAM
DRAM Size 256 MBytes
CAS# Latency 2.0 clocks
RAS# to CAS# 2 clocks
RAS# Precharge 2 clocks
Cycle Time (TRAS) 5 clocks
Bank Cycle Time (TRC) 7 clocks
# of memory modules 1
Module 0 SDRAM PC125 - 256 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
