Help with GPU Issue
Darktoast35
I've had my PC for a little over a year with no issues until just now. I'm suddenly getting low FPS in every game and the GPU fans are VERY loud. I have a Radeon 380x. MSI Afterburner says my GPU load is at a constant 100% with occasionally dips all the way to 0% then immediately back up to 100, temp is 76c. This is when idle btw. I've tried rebooting and reinstalling drivers. Anyone know what the issue is? Is it something I can fix, or is a new card the way to go?
http://www.tomsguide.com/faq/id-1691891/removing-malware-proven-completely-remove-bitcoin-mining-malware.html
sounds like you got miner malware
If that's the case, How would you suggest removing it? MalwareBytes isn't finding anything.
