Help with Ocing
sa_ill
61
I have an E5200 processor and a Gigabyte G31M-S2C mobo teamed up with 2GN Kingmax DDR2 800 RAM
I'm having problems overclocking. Can any tell m if wanna reach speeds of 3.6 or 3.8 what volt I should use and what FSB should I use?
The CPU OCing guide doesnt have a guide for my processor.
I'm sorta new to thiis overclockcing thing, so it would be great if someone could guide me.
k. start with 240fsb at stock voltages. leave the multi at 12.5x, leave RAM at stocks... turn off C1E and EIST etc... thats a nice simple overclock. then if thats stable for a few hours in orthos, drop the multi to 6 and try 266, then 300, 333.. once you reach your maximum FSB, up the multi .5x a time and orthos for a few hours.
i have mine stable at 3.6/3.7...
What bout the volts?....how do i increase/decrease them?
Plus do I overclock RAM?
Can my RAM be overclocked?
Whats C1E and EIST?
read my post... leave volts at stock for 240. anything above that i would say give the cpu 1.3625 (ONLY IF YOU HAVE AN AFTERMARKET HEATSINK WHICH I STRONGLY ADVISE)
you don't need to overclock the RAM. at stock, the RAM can be running at 400mhz :lol: its pretty much impossible for e5200's to run at 400fsb (800MHz RAM) so... no need to overclock your RAM.
I thought you said you had actualyl read the guide... its pretty much the same as the rest of the core 2's. omg. google C1E and EIST, or
READ
THE
STICKIES
ok been trying OCing and then testing with OCCT
It crashed at 12.5,12,11.5, 300 FSB, 800 RAM and 1.3V...but it always crashed after 2-3 mins
Next....at 11x (3.45Ghz), everything same except the volts at automatics, OCCT ran for 18 minutes
Any suggestions?
Yeh actually I have a stock cooler for now.
I had a doubt, if I get an aftermarket cooler and a nice OCZ RAM, how much approximate can I overclock till?
