Help with power supply for amd 6970 hd
for God's sake concentrate with me... when you turn on the PC do you get the MOBO logo and you go into windows environment ? or you see a black screen ?
if you see a black screen you have a problem then. if you go to windows but the HD 6970 is identified as a standard VGA adapter, you're fine and you have a simple problem which is the driver installation.
windows starts no bother, i think is a driver problem as stated above, i'm downloading new version on internet as we speak, also i have problem with secondary hard disc, its there in devise manager but dont come up on my computer, i activated slot in bios but still the same
sata hard disc settings is on ahci mode, maybe thats why secondary hdd dont pop up in my computer? what should it be set to?
primary hard disc is ocz solid state working on 6gbs options is
ide
ahci
raid
gpu is working fine now, thanks lads , new drivers done the trick, only thing is to get that secondary hdd going and we all set to go
mobo is asus p8p67 pro rev3, hard disc is western digital 1.5gb, can be found working perfect in device manager, i changed that to raid to try it and it said its instaled and ready to use, but still not there when you open my computer
i know, silly me, but then again i'm working as a stone mason, and that build was a bit of a challenge to me, i'm well pleased with the computer done that windows rating where it rates from 1-7.9 and all came in at 7.9 apart from first line that was 7.8
ssd is running on marvell sata 6gbs connection, on the manual says: for data drives only atapi device is not suported
secondary hdd is running on normal 6gbs port but its only 7200rpm should i plug it in to 3gbs port?
got it sorted all it needed is to asighn letter and format it, last problem is i have same problem with internal card reader, its there in the windows and bios but not in my computer window
