Help with power supply for amd 6970 hd
Yah that's a really cheapo case.Especially for such high quality components like your using.
The HAF 912 is fairly cheap but still offers good expandability.The HAF series are really wide so they can accommodate a bunch of really tall coolers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=HAF%20912
The Antec 300 Illusion is also a good option.But if your using the Noctua I suggest going with the HAF to get as much clearance as possible.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
yes it fits, the only thing if i fit secondary hard disc inline with it will be very close to gpu so i'll keep that couple slots below, primary had disc is solid state and very small so no problem at all
but you still need a decent case for the best fit and better cooling
lads still havin problems, got my power supply today, connected up, screen turns on, windows starts, but it doesnt reconize my video card, card is working as the fan is turning and monitor is working (connected to gpu) i'm using windows 7 64bit, if you going in tom change resolution it says, standart graphics adaptor, did i connected something wrong
there isnt 8 pin, only 6+2 pin x3, but i dont think their 150w as 6pin is only 75w and the other extra 2 looks like ground
6+2 pin is the (8 pin) hook the 2 pins near their brothers (6pins) and connected it to the GPU, and take a single 6 pin and hook it up to the 6 pin (female) in the GPU
those ones
dont work that way, i tried i cant see that suplieing 150w as 6 pin only 75w, i tried to switch bios on the graphic's card, but no luck either, as on my old car i had to switch it to work
don't make your own assumption, the 6 pin gives 75W and the 8 pin gives 150W i'm not electrician to tell you how it works. but they supply power as i said and the PCI Express expansion slot itself gives 75W
no, where do i do that? i dont think it was ever on anyway, i was using 4870 before that and i didnt had to disable anything
the on board graphics card is disabled automatically once a discrete GPU is installed, and if it's still on you should hear the PC peeps and everything running normally.
@ gedis what's your problem ? are you having problems getting signal from the GPU ? or you have a windows problem ?
i think its signal from gpu, vindows should have no problems as its only 2 weeks old and never been on internet yet, maybe it needs updates or something?
