Ok,ok ive done some guides... but just to be sure...
my system is going to be:
fx 8150 bulldozer cpu (maybe OC at 3.9)
M5A78L-M USB 3.0
2 sticks of 4gb vengence DDR3
4 hdd satas
5 120mm fans (3 with leds)
multicard reader with fans controller and lcd display
(maybe) 5.15 hdd fan
I'll use the onboard graphics card for at 3 mouths or so... but when i ll get the graphics card i want the better that the CPU can handle (at max 250 pounds)(without upgranding the PSU)
ive calculated, and i think ill be fine with a corsair 600 or 650w... and ive seen the "Winpower 850W" that is used as a 600w, but its like 2 times cheaper 😉 ...
what do you think?
big thanks
M5A78L-M USB 3.0
4 hdd satas
what do you think?
big thanks
