Question Help with ram clock speed G.Skill ripjaws v 8GB
Aug 29, 2020
I can't get my pc to post if i use the xmp profile or manual clock the speed to 3200 mhz it refuses to post and only clocks the speed at 2133.
PC Setup: cpu: RYZEN 3 3200G not over clocked. with amd wraith max
motherboard: Asus TUF B450-plus gaming atx
Ram: G.Skill Ripjaws V series 16GB 2x8GB
HDD: WD 1tb, SSD: PNY CS900 120GB
GPU: EVGA GeForece GTX 1060 3GB FTW+ Gaming
PSU: Corsair CX 500 W 80+ Bronze
What BIOS version are you running with your system? RAM stability and compatibility is added with BIOS updates.
RAM should be installed in A2 and B2 when you have two sticks. Make sure they are in the proper slots. Second slot and fourth slot starting from the CPU side.
